17x8.5 +30 / BC Coils with Front and Rear Camber Plates / Will they fit?
batmang
Dunna dunna dunna....
2003 Mazdaspeed Protege
Anyone have any experience with 17x8-9" wheels with a +30 offset fitting their MSP?
9" will probably poke and require a lot of fender massaging/camber. I am running 17x8 +52 with tokicos and it required a spacer in the rear to clear the strut.
horns, do you have BCs as well? Or stock struts? I am under the impression that the stock struts are larger diameter and therefore rub on wider offset wheels.
I have a new set of BCs in the box in my garage waiting to be installed, but right now I am on Tokico blues and Tein S techs. The coils are much smaller than the stock struts and allow more clearance than stock struts, but it is not a significant change. The wheels still have to fit under the spring perch of the strut.
You may be able to find more photos through google but here it is. His name is Swirlfx. These are 17x8.5 +30 w/ 215/45/17
