mspeed3420
- 2008.5 Mazdaspeed3
hey I just ordered these Eibach pro-kit 15mm spacers and it didn't come with what u use to tighten the spacer to the origional studs are (I dont know what theyre called but they look kinda like washers and screw on to the origional studs to keep the spacer stuck to the rotor). Anyone know if they messed up or do we have to go buy these?
Also, is this ganna rub with my bc coils? I can fit about a finger in between the tire and fender. Since I cant put on the spacers because Im missing that part, I cant lower it back down with the spacers on. It looks like its ganna stick out of the fender a good 1/2 inch to an inch instead of being flush with the fender like I want it to be but it might be just because its jacked up on one side of the car. do you think its just cause its jacked up? anyone lowered around the same as me and 15mm spacers? does it rub or stick out past the fender at all?
