03.5 MSP Odometer Swap
NCoppersmith
Mazdaspeed Protege 3.5
The speedometer in my MSP got "sticky" where it would jump between 45mph and 60mph depending on how fast you were going, not giving a good, gradual, needle sweep indicating speed at certain ranges. So, even though minor, I decided to swap the gauge cluster, thinking I could swap the PCB without too much difficulty. Then I discovered that the Tach and Speed motors were soldered to the PCB, making this impossible without popping the needles off, which I did on the original cluster, which probably borked it to begin with.
My car only has 69k miles or so (been in storage the last 5 years and never driven much, 2nd owner) but the used cluster I bought has over 235k miles. Is there a way to either fix my speedometer without soldering/de-soldering the speedo motor, or swap/fix the odometer on the replacement? While I might never (probably) sell this car, the mileage being out of whack kinda annoys me.
They are not soldered, there are 4 pins soldered to the pcb for tach and another 4 for the speedo, just straighten the 2 tabs for speedo/tach then they slide off the pins from the front to either swap gauges or pcb.
Latest posts
