Greetings everyone, new owner of 2018 CX-5 Grand Touring that needs some work.
I have been starting it to move it around and had no issues till the other day when I turned it off, tried to start it, but it wouldn't. Also, the shifter is stuck in park. Right now, I have the 'keyless system malfunction' and the push button flashes in amber.
- The car battery is charged at ~ 12.6,
- The stop light switch works fine; I checked resistance and lights.
- I replaced they keyfob battery.
- I overrode the shift lock and moved the shifter to Neutral, still won't start.
I'm trying to rule these out:
- Shift-lock solenoid
- Not P position switch
- Brake switch
- Start stop unit
- PCM
My first question is, is the 'Keyless system malfunction' a generic message when it can't start or is it possible that there is a communication issue?
Any info would be appreciated, thank you!
- Start stop unit
- PCM
