Is Torque Pro worth the upgrade? I'm still using the Lite version and been contemplating upgrading to Pro.I use the elm327 one. I also use an android app called Torque Pro. I've used it a couple times on the cx9 so far, it seems to work. It occasionally has connectivity issues but when it connects or works pretty good.
Honestly, I can't remember why I upgraded to Pro. Does the lite version allow for plugins? I know I needed a plugin to get some of the Nissan specific codes from when I was driving my Murano. At any rate, if the lite one is working for you then might as well stick to it. I tried other apps too, but Torque, with all it's quirks, and it is quirky, seems to be the best.Is Torque Pro worth the upgrade? I'm still using the Lite version and been contemplating upgrading to Pro.
