MazdaSpeed626
- Mazda 626 1998 5spd 2.0l FSDE
Soooooo, here is what has happened to my engine lately. I've got CP pistons and had been running them for a good while, melted one of them at the track on c16 and 21 lbs of boost with an unknowingly fried wideband....Much fun. After tearing the block down, turns out my pistons had broken 3 of the 4 oil squirters off....cool.
So after replacing the melted piston, i told the machinist(which is an extremely reputable shop here in town) i wanted the pistons filed down to make the oil squirters fit. He told me the reason they broke off was because they weren't positioned correctly....So i told him, fine, i'll let you assemble the entire bottom end and then you can position the oil squirters perfectly.
Well....long story short i took off my oil pan to fix a leak and found 2 broken oil squirters......that was a bad day indeed.
Needless to say i'm not putting new squirters in, so i've already removed all of the squirters(which was a huge b****) and am tapping the holes and plugging them. My question is what is the best way to clean out the shavings from the tap?
BTW, i've already pulled the engine and its on the stand, but still fully assembled minus the oil pan and sandwich plate.
