New Product Release! 2014+ Mazda3 and Mazda6 Adjustable Rear Camber Arms!
JBR
Authorized Vendor
09' & 2011 MazdaSpeed3
Details: Rear camber arms are often overlooked when it comes to lowering until the rear tires need to be replaced after only 10k miles.Unfortunately, the stock suspension does not allow for the necessary adjustments to correct this problem.
Adjustable Rear Camber Arms correct the additional negative camber generated when a vehicle is lowered.Not only will they aid in camber correction but they also allow for you to add up to +-4 degrees of camber for on the street or the track. Constructed from high strength extruded steel tubing they also come reinforced with thick steel gussets to prevent any unwanted flex or stress.Fitted with durable urethane bushings, control and road feel is increased with no need to worry about any added noise.
Sold as a set because we know you don't want just one. www.jamesbaroneracing.com Includes: 1 Set of Rear Adjustable Camber ArmsInstallation instructions are available in our support sectionShipping is free in the US & our Hassle Free Lifetime Warranty is included
Wow nice !
Does the outer end need to be unbolt to adjust when doing the alignment ?
