New Product! JBR 2004-2013 Mazdaspeed3 & Mazda3 Adjustable Front End Links
Made in USA and Free Shipping on all orders shipped inside the US.
jbarone
Authorized Vendor
09' & 2011 MazdaSpeed3
Details:
The JBR Adjustable Sway Bar End Links provide up to 25mm (1") of adjustment allowing you to eliminate sway bar pre-load or to fine tune sway bar pre-load for specific racing types and corner balancing.
The main body is 19mm (3/4") constructed from 6061-T6 billet aluminum and anodized black for corrosion protection. They feature a section machined on either side for easy on the car adjustments.
The spherical rod ends are specifically engineered for automotive suspension applications. They eliminate binding and provide the lowest amount of friction possible. The slotted nylon race and a heat treated and polished hard chrome plated ball make for long lasting smooth operation. The housing is also heat treated, hard chrome plated 4130 chrome molly steel. Weather resistant rubber face seals are included and provide extended protection of the bearing and race against salt, rain and dirt.
Class 8.8 mounting hardware and conical spacers finish off the kit making installation a breeze.
Features:
-On-car adjustable without the need to disconnect either end
-Eliminates undesired sway bar pre-load
-Assists in corner-balancing
-Nylon races for long-life and smooth operation
-Works with OEM and aftermarket* sway bars
Applications:-2013 & up Focus ST
-2016 & up Focus RS
The Kit Includes:
-1 PAIR (2) JBR Front end links
-All necessary mounting hardware
-Free US shipping
-2 year warranty
* Works with OEM and aftermarket sway bars that have the same mounting hole diameter and clearance as the OEM.
Latest posts
Top
