MODS:
Driveline:
Driveshaft shop 500HP Rear axles
Turbine Tech front diff mount
Jeremy-modified Street Unit Stiff Diff rear diff mount
Revised transfer case
SURE Torque-R6 "dogbone" mount
SURE aluminum shift box bushings
Rear shocks replaced with OEM equivilants (<10k ago)
Engine:
BNR stage 3 turbo
3" Downpipe
diyautotune.com Boost Control Solenoid
Cobb Turbo inlet pipe
Cobb Short Ram intake
Shimmed OEM bypass valve
EGR delete
PCV catch can
Throttle body coolant bypass
VTCS delete (intake manifold secondary butterflies)
intake manifold #1 runner ported (look for photos online, you'll see why)
VTCS rod holes filled
Balance Shaft Delete
Electronics:
Cobb AccessPort (stage 2+ tune currently)
Remote start (only works when the car is in neutral, pretty sure it's the only one like this!)
"AUXmod" (stereo input)
LED front running lights, LED strips in front signals
Yellow projector fogs mounted in headlight housings (not hooked up)
3000K HID fogs
