TiGraySpeed6
- 2006 Speed6 #3476
Notes on fluids & associated part information for the MS6
Please do post corrections or suggestions-
I'll integrate to this post as appropriate
This was mostly copied & pasted from dozens of posts,
or taken from the '06 MS6 owners manual
-notes gathered mostly just to make my life easier.
based on US dollars, quarts or gallons
> Fuel Tank
'06 MS6 Manual - 15.9 us gal
> Power steering fluid
'06 MS6 Manual - ATF M-III, M-V, or equivalent (e.g. Dexron II)
dry fill- 1 quart
> Brake/Clutch fluid
'06 MS6 Manual - SAE J1703, or FMVSS116 DOT-3
system flush- 1 liter
> Coolant
'06 MS6 Manual - 8.5 us qts (2.25 us gallons)
Type- Mazda FL22
Mazda OEM - part# 0000-77-508E-20
It seems that only mazda has coolant called "FL22"
Whatever, per their own service bulletin-
"FL22 coolant is compatible with current (Green) ethylene glycol coolant."
Bulletin No: 01-033/07
http://www.mazda6wiki.com/w/images/7/72/01-033-07-1830b.pdf
> Engine:
5.5 - 6 qts
7 quarts with Balance Shaft removed
'06 MS6 Manual - 5W-30
There's a strong argument being made that 5W-40 or even 10W-40
is better as the slightly thicker viscosity will not seep past the seals
in the turbo and may help prevent the smoking turbo syndrome.
Oil Filter - cartridge style
Oil Filter Part Numbers:
FL-2017B - Motorcraft/Ford OEM cartridge oil filter
L321-14-302-9U - Mazda OEM cartridge oil filter
7203 - Napa Gold cartridge oil filter (made by Wix)
57203 - Wix cartridge oil filter
L15505 Purolator Premium Plus cartridge oil filter
PL15505 Purolator Pure One cartridge oil filter
GL15505 O'Reilly's/Microgard cartridge oil filter
P7313 - Baldwin cartridge oil filter
HP-7013 - K&N cartridge oil filter (made by Champion Labs)
84203 - Carquest cartridge oil filter (made by Wix)
LF594 - Hastings cartridge oil filter
CH9641 - Fram cartridge oil filter
P960 - Champ cartridge oil filter (Champion Labs, makes oil filters for other companies)
S9641 - STP cartridge oil filter (made by Champion Labs)
M1C153 - Mobil1 cartridge oil filter
Oil Filter Wrench - 76mm/14 flutes
Crush Washer-
Mazda OEM - part# 9956-41-400
**NOTE - Short interval oil changes- fuel shear from DISI is bad mojo
> Tranny:
'06 MS6 Manual - API Service GL-4 (SAE 75W-90)
3 qts - GL-4
2.5 us qts actual fill
-Amsoil
Synthetic Manual Transmission and Transaxle
Gear Lube 75W-90 API GL-4 (MTG)
$12.90/qt retail
-RedLine
MT-90 (75W90 GL-4 Gear Oil)
$11.49/qt retail
-Motorcraft
Ford Manual Transaxle fluid # XT-M5-QS (75W-90 GL-4 Gear Oil)
> PTO & Rear Diff:
'06 MS6 Manual - API Service GL-5 (SAE 80W-90)
3qts - GL-5
'06 MS6 Manual - pto - 1.3 us qts actual fill
'06 MS6 Manual - r.diff - 1.1 us qts actual fill
-Amsoil
SEVERE GEAR Synthetic Extreme Pressure (EP) Lubricant 75W-90 (SVG) GL-5
$13.25/qt retail
Long Life Synthetic Gear Lube SAE 75W-90 (FGR) GL-5
$11.20/qt retail
**NOTE: My amsoil rep no longer stocks Synthetic Gear Lube SAE 80W-90 (AGL), and states the SVG is substantially better. I have heard from a few folks happily running the SVG in the MS6 rear dif without adding the SlipLock additive, seems it's not needed for the MS6. I removed the AGL from this list, but if you find it locally it will be fine to use.**
-RedLine
75W-90 (75W90 GL-5 Gear Oil)
$10.95/qt retail
**NOTE: Not recommended to run RedLine 75W-90NS - doesn't contain the friction modifiers for limited-slip rear diff**
(retail pricing from maufacturer websites september 2008)
DIY Pictures:
Trans:
both plugs 24mm (note: you will need a box wrench or similar to get at the fill plug)
Transfer Case/PTO:
drain plug is 24mm and refill plug is 23mm
Rear Differential:
drain plug is indeed 24 mm. and the refill plug is indeed 23 mm.
helpful hints:
the plugs are all either 23 or 24mm (see above for specifics)
the crush washers (if you are replacing) are part numbers:
Trans oil plug washer - A601-17-117
T-case oil plug washer - 9956-21-800
Diff oil plug washer - 9956-41-800
A pump of some kind is highly recommended for all three locations.
-Basic, inexpensive hand pumps can be had from almost any parts store
> Fuel Tank
dry fill- 1 quart
> Brake/Clutch fluid
> Coolant
Type- Mazda FL22
> Engine:
5.5 - 6 qts
Crush Washer-
> Tranny:
3 qts - GL-4
-Amsoil
$12.90/qt retail
-RedLine
$11.49/qt retail
-Motorcraft
> PTO & Rear Diff:
3qts - GL-5
-Amsoil
$13.25/qt retail
$11.20/qt retail
-RedLine
$10.95/qt retail
DIY Pictures:
Trans:
Transfer Case/PTO:
Rear Differential:
helpful hints:
