Even though its only 2 months old ?It doesn’t take much to drop the level below the low mark. Not uncommon that you may need to add a cup or so every so often.
Very common as Mazda has the tendency to under-fill many fluids from factory. It’s been verified time after time that the brand new CX-5’s have low engine oil level (although some may argue that oil level in between Full/Add or Max/Min marks on dipstick is fine)、engine coolant、ATF、and rear differential lubricant. Some dealers may do a better job to top off some of the obvious ones during the new car preparation, but many of them may not bother. Go to your Mazda dealer and ask them to top off it with Mazda genuine FL-22 coolant perferably watching the tech to do it as some may just add tap water instead of expensive FL-22 coolant!i noticed that the engine coolant was under the low mark in my cx 5 2017 with 2500 km on it, brought it to the dealer and they added half a cup ?
Its been very cold but kind of surprised that i could not see any coolant .
When we picked up our special-ordered brand-new 2016 CX-5 GT AWD just unloaded from truck I found the engine oil and coolant levels were low. I also checked several brand-new CX-5’s in my dealer’s lot at the time and ALL of them had engine oil and coolant levels in between Full and Add marks.
Thats exactly what i did , they topped it off to full line .Very common as Mazda has the tendency to under-fill many fluids from factory. It’s been verified time after time that the brand new CX-5’s have low engine oil level (although some may argue that oil level in between Full/Add or Max/Min marks on dipstick is fine)、engine coolant、ATF、and rear differential lubricant. Some dealers may do a better job to top off some of the obvious ones during the new car preparation, but many of them may not bother. Go to your Mazda dealer and ask them to top off it with Mazda genuine FL-22 coolant perferably watching the tech to do it as some may just add tap water instead of expensive FL-22 coolant!
What he said^^^^
Mine was a little low and I had the dealer top it off. Again, it wasn’t so low I think it would have caused major problems.
I am also pushing the stock oil 7k miles.... then it’s full synthetic!
I didn’t think they used it stock on the CX-5? I could be wrong tho? I thought it was a synthetic blend?
Synthetic blends are an oil industry joke. I doubt any OEM would consider using one.
If you believe this then this means Mazda wants to be different from everybody else and all the fluids are not needed at the Full mark from factory. All dealers including Mazdas will top these fluids off to the Full mark if you ask for it because traditionally the Full mark is the fluid level you want to be at when you check it and top it off.The factory does not underfill it. Machinery meters it out. Yrwei likes to repeat this though.
"Full" does not mean "optimal" or "necessary".
Mine was actually pretty clear but was a low fill from factory. I couldnt feel fluid level through fill hole. Replacement criteria as per fsm is to right at the bottom of fill hole.
The owners manual says the factory-fill is Mazda genuine 0W-20 oil. The UOA shows the factory-fill is very likely to be the moly-rich Mazda 0W-20 full-synthetic moly oil. In addition therere very few synthetic blend 0W-20 oils available on the market.So, they are in fact using synthetic oil?
Fake stories? So youre questioning many long time members here spreading fake stories about the low-fill on factory fluids? And how frequently weve seen new CX-5 owners complaining low oil level and low engine coolant?Mazda does not underfill fluids. As mentioned several times before, the fluids are metered in exact proportions. Stop spreading fake stories.
Back to block
