- 2008 Mazda5 Touring
I have the main parts together for a fully automatic heater core bypass system.
If you have replaced your cabin filters or been at the passenger foot area for any reason while the engine was running or not long thereafter, you may have been nearly scorched like myself from a gentle touch of the heater core pipes that are within inches of the a/c evaporator. I've already done the evap temp sensor mod, but am hoping that a greater benefit will be the approach of keeping the hot coolant out of the passenger compartment altogether. Reading on other vehicle forums, this mod can decrease the a/c output by 5* or more - very noticeable. IOW, if it's hot outside and your a/c is blasting, it won't be fighting the heat of the heater core as well.
The basic components are as follows...
The basic operation is as follows...
If the weather and my wife's schedule cooperate this weekend, I'll pickup some vacuum line and antifreeze/coolant. I'd be happy to do a 'How-To' if any are interested.
The e-thermostat senses ambient air, then at a user adjustable temperature (approx. 80-85* F), engages the VSV, which - via vacuum to the bypass valve - diverts coolant back to the engine without traveling through the heater core. Once ambient temperature drops below the preset point (1* or so hysteresis), the e-thermostat disengages the VSV, which then causes the bypass valve to route the coolant normally through the heater core.
