This is kind of a weird question, but does anyone know whether the front drive axles connect to the transaxle or the transfer case? I know on most older 4wds they connect to a front differential, but the CX-5s don't have a front differential.
Thanks! Reason I ask is, my 2016 is going to the dealer for this TSB:
Axle inner joints will be replaced, which means axles will be pulled and fluid will likely leak from either the transaxle or the transfer case. I want to check it after I get it back to make sure fluid levels are topped off.
Thanks so much!
Thanks so much!
