First CX-5 oil drain
Status
Not open for further replies.
erhayes
Contributor
CX5 Reserve
I just did my first oil change and wanted to share my findings. When I removed the drain plug I looked at the oil pan to remove the plug gasket and non was there. I found the aluminum gasket painted on the plug. The pan was pained with plug in place. I had to use a sharp knife and insert it between the plug and gasket and give the knife a sharp wack with a piece of wood to remove it. I can only wonder how many engines have two gaskets running around. Just a thought. Ed
2019 CX-5 Signature
Had a similar issue with ours. I do not lift the vehicle, so I didn't get a good look at it to see if it was painted on. I used a similar method to get it off.
2016.5 CX-5 GT AWD titanium/black 2016 Miata Club ST MT white
Mine was the same way. I know that I'm tempting fate but I reused the stuck on aluminum washer even though I have a bag full of them.
yrwei52
Contributor
Plano, Texas, USA
Yep it’s been mentioned many times before:
⋯ only hiccup was I had a very hard time getting the old aluminum crush washer off the drain plug flange, it was really stuck on there, I had to use an xacto knife blade to separate the old crush washer from the drain plug.
note: I can easily see for any first timer to think that there is no crush washer or if they lost the crush washer when it's actually there stuck on the plug flange, I thought the same thing it looked like one piece and the crush washer was missing, but when I compared the new crush washer supplied by Med center Mazda versus the drain plug, I can clearly see the crush washer stuck on there. I used a miniature flat blade screwdriver but that didn't work so I used an Xacto knife to get that damn thing off. I hope no one doubled up on the crush washers thinking the original crush washer was part of the drain plug.
2018 AWD GT Premium Red/Black
It also takes a ton of torque to break it loose. I thought the shop must have overtorqued it, but the 2nd time I did mine, it also took some effort to crack it free. Now I use a Fumoto valve.
Pueblo county CO
CX-5 Sport 16.5 6M
I don't tighten mine too much. I use a 14mm neoprene washer like the Honda plug has.
2018 CX-5 Sport
It seems like you have been here forever, this is your first oil change?
2020 CX5 Signature
Foolish question: I have a 2020 Signature purchased October 2020; what type of drain plug do I have? In other words, what tool will I need?
sm1ke
Work In Progress..
Moderator
Contributor
Canada
'18 CX-9 Signature
I think the newer models use hex bolts, so you'd use a hex socket. I don't remember the size though.
Status
Latest posts
