CX-7 2007 Engine fan won't turn on, help!
Mazda CX7 2007
Replaced my power steering pump and belt but my front fan will not turn on, my temp is super high and will not go down. Please tell me what is wrong and what has to be replaced? Anything helps, thanks!
If you're saying the coolant temp is high even when you drive the vehicle, then that's not a result of the fan failing to run. It would mean multiple problems, with the fan being one of them. Also, it's not clear if you're saying all of this started happening after you did the work (if not, then why did you mention it).
Upvote 0
