marcs_sp20
- 02 Mazda 323 Astina SP20 (P5)
Hey guys,
Over the past few mornings I have had CEL P0328 appear on the ScanGauge - Knock Sensor (high input bank 1)
I have checked the connector this morning and seems to be fine (from what I could feel - the knock sensor is above the oil filter so a total PITA to get to). I have only been running 98 octane fuel for the past 6-8mths, so im not getting any pinging. Its only appearing on teh scangauge of a morning, with the current temps in ipswich at 7.30am around 5degrees the past couple weeks The car is warmed up for around 1-2mins before being driven, and im averaging around 500kms/tank, even with the colder weather..
So, in saying, the Knock Sensor talks to the ECM in which it retards or advances the timing, so could the colder weather be tricking the car and making the cel appear? On the weekend Im going to be going back to stock intake to see if this makes a difference.
Any other suggestions? I really dont want to fork out $180usd for a new one, and I would hate to know how much one would cost here in Aus!
Cheers
Marc
Possible causes
- Knock sensor circuit short to GND.
- Knock sensor circuit short to PWR.
- Knock sensor circuit open.
- Damaged knock sensor.
- Powertrain Control Module (PCM
Possible solution
- Repair or resecure harness or connector
- Replaced knock sensor
When is the code detected?
- An excessively high voltage from the sensor is sent to Powertrain Control Module (PCM) or Electronic Control Module (ECM)
P0328 Description
The knock sensor is attached to the cylinder block. It senses engine knocking using a piezoelectric element. A knocking vibration from the cylinder block is sensed as vibrational pressure. This pressure is converted into a voltage signal and sent to the Powertrain Control Module (PCM) or Engine Control Module (ECM).
Cheers
Marc
