Mikeyman64
Zoomer
- Atlanta
- 2002/2003.5 "MSP5"
Hello there follow zoomers,
I've got a 2002 Protege 5 2.0L 5spd. It's had a problem that has lasted through a tire change, strut change and 3 different alignments/balancings.
The problem is a sound. The best way I can describe the sound is "woop woop woop"... So, yeah. Some symptoms are:
Sound is worse (sharper) when I turn left.
Sound is still quite audible (bot not as sharp) when turning right.
Sound is barely noticeable when going strait.
Sound gets really bad when going over 55mph and then is back to usual at around 70mph.
-Could be related
Car veers ever so slightly to the right at any speed.
Car pulses slightly when applying brakes at low speed (e.g. approaching a stop sign). Bud that could be my pads (changing this week).
The first thing I thought it could be was maybe my right CV joint, but when I did some research, I found that most of the time when a CV joint "goes bad" it means that the boot has cracked/split and the grease oozed out. It will also make a loud "clicking" noise. I had this info backed up from a buddy who, in fact, did have a bad CV joint.
So then my second thought was my right wheel bearing. That would account for the "woop" sound and the veering.
Seeing as how one bearing will cost me $31.30 + shipping, and because I'm a bit obsessive I will probably get 2 (makes things even), I though that before taking a $62.60 risk, I would ask people that know what they're talking about. Any input would be greatly appreciated.
-Could be related
