Your '06 may very well have an older, non-smart charging system - IDK because I don't have access to a wiring diagram. However, even if it does, and you could trick it into producing max voltage, doing so would probably trash the alternator fairly short order. Alts are not intended to run at max output continuously, so you would be much better served by buying the HO which will run somewhere in the middle of its curve. But as always, your vehicle, your choice.
