2016 LED Headlights Low beam
Hi everyone
I have a 2016 Mazda CX5 GT with LED headlights, the question here is if I can change the headlight bulb without changing the whole unit? because it has gotten less bright
I don't talk about the LED strip of the DRL, i am referring to the Low beam lights
Thanks to all
EDIT: I’m an ass! You have my apologies for not even remotely reading your entire post!
I do believe the entire housing needs to be replaced due to the integration of the electronics.
I'm note sure on my answer here, but I've seen on the forum that there was a TSB for flickering LEDs on the later Gen 1's and the only solution was to replace the whole cluster.
