The window in my cx-5 doesn't open or close. I have replaced the motor and switch assembly and it still doesn't operate. Anyone have any suggestions to the fix?
Total shot in the dark: Did you check the fuses? My 2020 manual shows four fuses for power windows spread across the two fuse blocks.The window in my cx-5 doesn't open or close. I have replaced the motor and switch assembly and it still doesn't operate. Anyone have any suggestions to the fix?
I replaced the switch assembly which I believe houses the relays.Fuses? Relay?
You need a multimeter to check the electricity. Check first if you do have power to feed the switch and motor with ignition on but the engine is not running.When I connect a new motor and switch, press up or down, the motor gear doesn't turn. I get nothing, dead silence. BTW it's a 2014 cx-5.
