07 - 09 CX-9 wheels on 2019
I just got my 2019 CX-9 and am thinking about getting a set of wheels and snow tires for the upcoming winter. I have 20" but this model uses 18" as well. The 18" specs for my vehicle seem to match those of the 07 to 09 CX-9, except the 07-09 wheels are 0.5" narrower, which is ok for the 255/60R18 tires. Same bolt pattern, offset, and center bore diameter.
Has anyone used the older wheels on the newer generation? Anyone see an issue?
As you note, the only difference is the half-inch of rim width. Use any tires that fits that rim and is within 2% of the original outside diameter. We'll assume the wheels have about the same weight carrying capacity. It'll be fine.
https://www.wheel-size.com/
The offset--45 mm
The bolt pattern--5@114.3mm
The bolt thread--M12x1.5
The centerbore--67.1mm......all the same.
