I might be able to save you a few pennies:
There is zero benefit to putting a higher octane fuel in a car than it calls for. It's not any cleaner and your car won't run any better. Some engines require a higher octane to prevent spontaneous combustion (knocking) due to higher compression ratios.
If your car isn't knocking at a lower octane, there's no benefit to getting a higher octane. You're just burning money.
From CarTalk:
Q. My owner's manual says my car will run just fine on regular, unleaded gas. Will "treating" it to premium gas provide any benefit?
A. Let's be perfectly clear about this:
NO!
A. The only thing you'll be benefiting are the portfolios of impoverished oil company executives.
And before you do that, consider that Exxon-Mobil earned $39.5 billion dollars in 2006 - a world record profit. It's not like they need you giving them a hand out.
There's actually some consensus around here that in certain conditions, like high heat/humidity and hill climbing, that higher octane results in somewhat better performance because otherwise the engine senses knock and pulls timing, thus reducing power. It is a fairly high compression engine so this isn't rare, especially in warm climates.
