mark.crader
- 2003 Mazdaspeed Protege Spicey Orange :)
Almost forgot the coolant housing on the end of the head also has to be switched
Sent from my SM-N920P using Tapatalk
For the oil feed i used the feed line from the msp and tapped into the oil pressure sending unit on the back of the block. For the oil return i used the sandwich plate (plate between the oil pan and the block) for the oil return
You have to swap the upper oil pan/MBSP from the original block to the new one, that's where the oil drain is.
