ozz said:if anyone has a chance can they check to see if their paint is being worn away under their license plate fram
MikeBlueP5 said:Are you talking about the front or rear tag plate frame?
My tag frame on the rear came with two little rubber pieces at the bottom so it really doesnt even touch the car, for exception of where it is bolted.
Mike
WhiteZoomZoom said:Wont hurt to ask...nothing to loose...right ??![]()
mnkyboy said:I checked mine about 2mths after I bought it. Damn f%ckers used long bolts to put the plate on, and it f%ucked the paint up :mad: I havent touched the paint up yet. What have you done about it??
bmorton said:
Same here -- the bolts they screwed the plate on with were so long that when they tightened them up they screwed right into the paint. I discovered this when I took the plate off to add my license plate cover. I just touched up the damage -- no one's ever going to see it anyway. Fortunately my plate cover was thick enough that the end of the bolts don't touch the paint anymore.
