Lost my college grant... evidently the state of Oregon can't afford to help educate me anymore. I've sold the mods to raise tuition money for fall term; hoping I don't have to sell the car.
thats gay, sell your swimmers
kidneys go for a decent amount, but there's always blood and plasma
parts should be in on wednesday, so maybe wednesday night or thursaday i should have my car back
if he has a gf he could have her sell her eggs they go for like 1000 a piece
Bone stock, no boost gauge. Idle is smooth and around 750 rpm so if it's a vac leak it's a small one. When it's warmed up and in open loop (or closed, whichever) is when it stumbles. I just cleaned the EGR and no dice, it runs the same. It's only under boost and gets worse as the car gets hotter.
So nobody has any ideas? Today I got a CEL it was a P0302 which it's thrown before, new coilpacks, wires, NGKs, PCV, air filter. Car runs like s*** when it's warmed up and misses, thinking maybe the MAF or a fuel issue, how can I test the fuel pressure? It feels like a flat miss, the car bucks under acceleration.
Soooo boost leak? check your charge pipes.
I pulled them off and they don't have any cracks, it runs smooth and pulls hard when it's cold but when it warms up it stumbles under any acceleration. Think a WGA would cause this? I couldn't blow air through the vac line to the wastegate.
Bone stock, I don't have anything done to the car. It doesn't seem to leak any boost when it's cold, it runs good. Plus i'm getting a misfire CEL, P0302.
check the bolts on your intake manifold, some may have come loose,
also, i would suggest making a boost leak tester, very simple and a great tool to have, i found numerous leaks in my car that i couldnt find before, and the vac was even spot on
there's normally a few air leaks around the injectors, possibly the PCV, and maybe at the TB
or you could just spray soapy water around the injectors while the car is running to see if it bubbles up, if it does then u got a leak
Have you tried swapping in a known good MAF, to rule that out?
so i should be getting a set of 04 mazda 6s rear calipers, brackets, rotors, and some hawk pads for them for a grand total of $40. :) so then all i got to get is ebrake cables. which are like $50 on rockauto, and ss brake lines. then the rear can go in. :) now got to start looking for the expensives stuff: front mazdaspeed6 calipers :(
keep in mind MS6 brakes marry you to a 17" or larger wheel. Just FYI.
How different are the MS6 front calipers & rotors from the regular MZ6?
Oh Noes. You can't run FD's! haha, just playin Wagon. Had to do it. (lol2)
