Because you used to have drums on the rear.....
You should know Damian, you did it before me!
Front rotors, front hubs, front calipers w/ brake lines, rear rotors, rear hubs, rear calipers w/ brake lines, all 4 rear lateral links, e-brake cables. That should be it.
Whoops! 5spd, not 5lug. Ok hold on...
Trans, half shaft, rear mm bracket, starter, driver side axle, metal piece in between trans and motor, flywheel, clutch, clutch alignment tool, side mm, clutch line, ecu, engine harness(or attempt to splice up the ATX one), brake pedal, shifter, 2 shift linkages.
I THINK thats all of it.
so with the clutch pedal assembly, were there already connectors in your stock harness to attach to the sensors on the clutch/brake pedals??
and the clutch line, did you have to run a totally new one from the master cylinder?
