R
Red08Speed3
I dont think this makes a difference at all, I bet its a mental thing if anything
If you use red wire, all the electrons run from the throttle body to the ground. If you use black wire, the electrons run from the ground to the throttle body. Make sure you use the correct wire for your situation.would it matter if use red or black 10 guage wire?
Funnier and funnier. Don't forget the 3' TB spacer.If you use red wire, all the electrons run from the throttle body to the ground. If you use black wire, the electrons run from the ground to the throttle body. Make sure you use the correct wire for your situation.
No.Haven't read the entire thread, but am one of those weird ones that like specifics...
Has anyone reliably confirmed any before and after statistics other than it 'feels' or 'seems' better ?
In case I confused anyone by this post, here is how you figure it out. Take a volt meter and connect it from your throttle body to the ground post of your battery. Put the red test lead of the meter on the throttle body and the black lead on the battery. If the reading is positive, you need to use the black wire. If the reading is negative, you need to use red wire. If the reading is very close to zero, you don't need the wire at all.If you use red wire, all the electrons run from the throttle body to the ground. If you use black wire, the electrons run from the ground to the throttle body. Make sure you use the correct wire for your situation.
Heck, go with AWG 4/0. It's only 0.04901 ohms per 1000 feet.would it work even better with #2 gauge wire ? less resistance so this should be better than #8
(hahaspit)
