folks with nitrous on a MS3??
well, the cardomain does pretty clearly show a dry nozzle in a boost tube. a reasonably stock car can run that way just fine. my car on the other hand would run wayy too lean with a dry shot. if i cant do a wet kit i dont want it. and based on how the throttle works on this car a good wet kit will probably never happen. unless it is armed off of pedal position instead of actual TPS. an dif done that way and teh car cuts for any reason, which these cars are well know for doing, you will have an intake backfire. that = total destruction of this little 2.3L !!
what i want to know is ...IF he has nitrous not "nos" ....wh yis it not in his signaure ? he has every other mod listed. EVEN s*** HE DOESNT HAVE YET !!
that makes me think if it was on the car it would be listed. i do see where it says custom IC sprayer. is that the nitrous ?? CO2 is cheaper to use for that purpose, but i suppose nitrous works.
There happy now. Now u know y it wasnt in my sig before. I will reinstall it this weekend just for u non beleavers.
Not a MS3, but this is my set up.
And boosting on a GT2871r
I've considered using a ZEX kit solely as an IC Sprayer.. but recently am leaning towards a CO2 or Cryo2 kit by DEI.
That is when I have money to blow on my car.. so I don't see me ever doing this lol.
Cp-E Reflash FTW!
I would not run nitrous on this car based off pedal positon because the throttle plate dances around with your foot pinned to the floor. I would question running nitrous on this car at all since the throttle plate doesn't fully open anyways and is always dancing around. Only way to get around that currently is the cpe flash that holds throttle at 100% wide open.
I believe the spelling of grammar with the latent E makes it possessive or plural. I firgit Does the CP-E really give the throttle plate a full 5volts!?
Yes, all 5 volts? Maybe i was mistaken. Ithink in england, a grammer is someone who has ... with very old ladies
I could be mistaken, but from I read on the "other, new" forum was that the value was like 3.7 volts for 100% open throttle plate. Nevertheless, yes its been done and the few who have the flash so far say its a huge difference. Dyno's should come in this week from what I hear. Dadasracecar has it and loosh was supposed to get it this weekend.
ok..... i do not have 2 prove s**t engulfinflames has seen my NO2 kit on my car and seen me running it on the track
don't be a hater because u are a kitty kat..... hehe
