*Mazda of the Month 2.0* Enter now for May!
Status
Not open for further replies.
How hard was it to put the headunit down below the ashtray?
Not that hard from when my friend shop installed like 4 years ago. Its just cutting the ashtray and lighter out that you might want to think about if you do this mod. Also some things I know its tighter to work behind there and a little gap you see unless you either cover up with EQ mount it the deck higher. And the deck blocks the use of my cup holders=( I think there was a thread about this before if want to check.
BoostedMP3
Chris
2001 MP3 #04
<a href="http://s27.photobucket.com/albums/c173/italianhotshot/?action=view&current=DSCN0076-1.jpg" target="_blank"><img src="http://i27.photobucket.com/albums/c173/italianhotshot/DSCN0076-1.jpg" border="0" alt="Photobucket"></a>
<a href="http://s27.photobucket.com/albums/c173/italianhotshot/?action=view&current=DSC00220-2.jpg" target="_blank"><img src="http://i27.photobucket.com/albums/c173/italianhotshot/DSC00220-2.jpg" border="0" alt="Photobucket"></a>
<a href="http://s27.photobucket.com/albums/c173/italianhotshot/?action=view&current=100_0333-1.jpg" target="_blank"><img src="http://i27.photobucket.com/albums/c173/italianhotshot/100_0333-1.jpg" border="0" alt="Photobucket"></a>
Exterior:
DGM Carbon Fiber Hood with Induction Cowl
DGM Blacked Headlights
Blue Line Under Glow Neons
35% Window Tint, 20% on Front
Blue Front Turn Signals
Clear Side Marker Lights
Yokohama Parada Tires
Interior:
Stewart Warner 15 PSI Boost Gauge
Autometer Pro Comp Voltage and A/F Guages
Blue Line Blue neons
Carbon Fiber E-Brake Handle
Engine and Mods:
Mobil 1 Synthetic Oil
Redline MT30 Synthetic Transmission Fluid
BEGI Stage 1 Garrett T3 Turbo Kit 8PSI with Sidemount Intercooler
Custom 3" Exhaust with Apexi A1 Muffler w/ no Cats; running open downpipe right now
2.5" Downpipe
K&N Air Filter Cone
Turbo XS RFL BOV
NGK zfr5f-11 spark plugs
AWR Front Motor Mount
Indigo Lightened Flywheel 8LBS.
ACT Stage 2 Clutch
MP3 Short Throw Shifter
Hawk HP Street F & R Break Pads
Spark Plug Non-Fouler Check Engine Trick
BoostedMP3
Chris
2001 MP3 #04
LMAO sweet license plate.
PRODIGY<o></o>
Chris Tyre<o></o>
2002 Mazda Proteg LX
Engine:<o></o>
Optima Red Top battery<o></o>
Port + Polished head<o></o>
Port + polished 626 intake manifold<o></o>
Mazdaspeed ECU (flashed)<o></o>
Mental Addiction Motorsports Sleeper turbo kit<o></o>
GT28R turbo<o></o>
FMIC w/ hardpipes<o></o>
Log style exhaust manifold<o></o>
Tial Sport 38mm wastegate <o></o>
MAM polished turbo heat shield<o></o>
MAM vacuum block<o></o>
Stainless steel braided oil feed + return lines<o></o>
Walbro 255lph fuel pump<o></o>
Aluminum fuel rail<o></o>
WRX 440cc injectors<o></o>
2.5 cat-less downpipe<o></o>
Custom 2.5" cat-less exhaust<o></o>
JoeP inline boost controller<o></o>
K&N cone filter<o></o>
Drivetrain:<o></o>
QUAIFE limited-slip differential w/ upgraded ramps<o></o>
Cryo-treated gears<o></o>
Fidanza lightweight aluminum flywheel <o></o>
Exedy stage-1 clutch<o></o>
AWR front & rear motor mounts<o></o>
AWR side motor mount inserts<o></o>
AWR deep sump, baffled oil pan <o></o>
Goodridge braided stainless steel clutch line<o></o>
B&M short-throw shifter<o></o>
Kartboy shifter bushings<o></o>
<o></o>
Suspension:<o></o>
JIC Magic FLT-A2 15-way adj. coilovers<o></o>
AWR 21.5mm rear sway bar w/ brackets<o></o>
AWR adjustable endlinks<o></o>
AWR rear trailing arms<o></o>
MazdaSpeed front strut bar (removed for Shannon's [1338] memorial in garage)<o></o><o></o>
<o></o>
Brakes:<o></o>
Brembo slotted & cross drilled rotors<o></o>
KVR Performance pads<o></o>
CorkSport stainless steel brake lines (front + rear)<o></o><o></o>
<o></o>
Wheels:<o></o>
Miata semi-hollow spokes <o></o>
Falken Azenis RT-615 <o></o><o></o>
<o></o>
Exterior:<o></o>
Bosch ICON wiper blades<o></o>
Removed side moldings<o></o>
Removed dealership + trim decals<o></o>
35% tint<o></o>
ES (black) headlights<o></o>
ES (black) grille<o></o>
Wilson "Lil Wil" CB antenna<o></o><o></o>
<o></o>
Interior:<o></o>
Mazdaspeed/MP3 interior swap <o></o>
Corbeau Forza fixed back seat<o></o>
Corbeau seat bracket w/ double locking sliders<o></o>
G-Force four point harness<o></o>
DIN sized angled triple gauge pod<o></o>
AEM 6-in-1 UEGO wideband<o></o>
AutoMeter sport-comp oil pressure gauge<o></o>
AutoMeter sport-comp boost gauge<o></o>
Megan Racing 2" weighted shifter ball<o></o>
DaveB polished aluminum gauge rings<o></o>
Apexi full auto Turbo Timer <o></o>
Valentine One radar/laser detector (hardwired)<o></o>
Cobra 18WXStII 40-Channel CB Radio (hardwired)<o></o><o></o>
Stereo:<o></o>
Alpine CDA-9827 headunit<o></o>
Kenwood 5"x7" front door speakers<o></o>
Kenwood 6.5" rear door speakers<o></o>
Kenwood 800W amp<o></o>
Alpine 15" Type-R subwoofer (2000w peak)
sm76
Bill Brees
2003 Mazdaspeed Protege
Performance Related Mods:
Self Fabricated Roll Cage
Self-Fabricated Seat Mount
Self-Fabricated Front Bumper and Tow Hook
Self-Fabricated Cat-Back Exhaust
Nitto NT-01 Tires (235/40/17, 215/45/17, 225/45/15)
KSport Coilovers (500 lb/in front, 450 lb/in rear)
AWR adjustable 21 mm Rear Swaybar
AWR Front Endlinks
AWR Motormounts
AWR Oil Pan
Injen Intake
Hardpipes
Corksport 2.4 S and J Pipes
2.5 Catless Midpipe
Split Second Air Fuel Controller
Carbotech XP-10 Front Brake Pads
Carbotech Bobcat Rear Brake Pads
Steel Braded Lrake Lines
ATE Super Blue Brake Fluid
G-force 5-point harnesses
Ultrashield Pro Road Race Seat
Fidanza Aluminum Flywheel
Exedy Stage 1 Clutch
Carbon Fiber Hood
Autopower Boost, Oil Pressure and Oil Temp gauges
ARP Wheel Studs
Lexan Windshield
Grant 12.5" Steering Wheel
Jeg's Steering Wheel Disconnect
Interior:
gone
Stereo:
gone
Racing Accomplishments:
2007 NASA TTE National Champion
2006 NASA TTE National Champion
2007 NASA OH-IN TTE Regional Champion
Current Lap Records:
NASA TTE Mid-Ohio Pro Course
NASA TTE Mid-Ohio Club Course
NASA TTE Grattan Raceway
Show cars > performance cars..... Don't we know this already (first)
You still have a chance.
EVADE
Efren
2002 Mazda Protege5
Engine:
Simota C/F Intake
HKS Hi-Power Axle Back
OBX 4 to 1Header
Spec Clutch Stage 2+(not installed)
Magnacore 8mm Spark Plug Wires
Cusco Oil Catch Can
Cusco Radiator Cap
Weapon R Engine Damper
NSN Motorsports Filled Motor Mounts(all 4)
1sty Ground Wires(Red)
Samco Radiator Hoses(Red)
Optima Red Top Battery
6K H7 HID Kit
Rolling Rock Radiator Over Flow Bottle=)
MazdaSpeed Enigine Cover with DGM Brackets
Billet Oil Cap
Custom Hood Dampers(30lbs. for Fiberglass Hood)
TWM Short Shifter
KartBoy Bushings
Suspension/Body Braces:
Tein Super Street Coilovers
Progress 22mm Rear Sway Bar
Cusco Front Strut Tower Bar
Generic Rear Tower(from MX6)
GTspec Front Lower Tie Bar
GTspec 4pt Ladder Bar
Universal Floor Bar(chrome)
Wheels/Tires/Brakes:
Rota D2 17x7.5 +48 offset 5x114.3
Bridgestone Potenza RE750 215/40/17
Muteki Open Ended Locks(black)
CorkSport Steel Braided Brake Lines(front and rear)
Brembo Drilled and Slotted(front and rear)
EBC Green Stuff Brake Pads
Exterior:
Full MintBlue Kit with JDM/EDM Rear Bumper and Bumper Brackets
AutoExe Wing
AutoExe Grill
Ion Performance Carbon Fiber Hood Painted
VentShade Visors
JDM Taillights with Hiper White Reverse Bulbs
JDM Front Tilt License Plate Holder
xelderx Custom Billet Antenna Powder Coated Black
Familia Badge(waiting for it to come in the mail from CorkSport)
Removed Side Moldings
OEM Roof Rack Strip
Interior:
35% Tint
Indiglo Gauges
Leadfoot Custom Gauge Bezel
OEM JDM Rear Cup Holder
Nokya Pedals
OEM Rear Hatch Plastic Floor Cover
OEM Rear Hatch Cargo Net
AutoMeter Air/Fuel Gauge
AutoMeter Volts Gauge
AutoMeter Electric Oil Pressure Gauge
AutoMeter Boost Gauge(just for show for now=)
Audio/Screens:
Alpine DVD/CD Receiver Model DVA-9861(custom mounted in ash tray)
Alpine Type S 5x7(front)
Alpine Type S 6.5(rear)
8" Bazooka(amplified)
7" XO Vision Screen(custom mounted in stock deck location)
10.5" Alpine Rear Flip Down Screen Model TMX-R1000
And I think we have our winner right here!!! You may now vote for MOTM for June.. thanks lol. Car looks bad ass man. Throw a CF hood on it and I think I would ask it to marry me!!!
D_Roc7822
Derek
2008 Mazdaspeed3
Mods:
17" ADR DV 8
235 40 17 BFG KDW2
Eibach Sportlines
TRZ Dog Bone MM (Poly)
Painted Calipers Blue
The car does have a CF hood on....it's just painted to match.
CHEE! Rem-Rem for the win. haha.
every time i enter, ppl come out of the woodwork with kick ass cars, if i dont enter, only 5 ppl show up for the contest...wtf
This coming from a guy who has a turbo, a race seat, a huge list of performance mods and a pic of his car on some road course in his sig.
might as well try again
cmm7v3
Chris
Mazda Protege ES
Engine Mods
msp turbo kit
Ingen cai
msp cbe
Suspension
Stock
Exterior
grill painted to match
adr flite 5 rims
Interior
scan gauge II mounted in radio bezel
pioneer deh 780mp
apple ipod
xm radio
daveb gauge rings
Status
