Just an FYI - This weekend I replaced my factory BPV with a Forge one (Blue with 2 shims). I'm running 19PSI using a TurboSmart with Map Clamp.
Before - With the factory BPV when I was crusing 80MPH in 6th my boost was at like 10-15Vac. Normal Vac at idle was like -26. When I got on it, my boost would shoot up to 19PSI then drop almost instantly to around 16-17PSI.
After - With the Forge when crusing at 80MPH in 6th my boost is at 0 vac/boost. Normal Idle is at -20vac. When I get on it now my boost shoots up to 19PSI and holds steady to 6k.
There is no question in my mind that my factory BPV was leaking like crazy and unable to hold boost past 16PSI very well.
