GI light weight pulleys
Status
Not open for further replies.
Just curious, are you going to build all 'x' amount and then do a test fit? Just curious, cause what if you build 20 and all don't fit? Or you build 20, and you find out they crack under tension or something like that?
Also, the i4 guys keep on posting seperate lists and the one from rainmens is different from the big list. Everyone should just tag on to the big list (uhm)
The pulleys are designed in Solid works and then plugged into the FEA program to ensure it will not fail. I have a local car that I am building the first ones on and testing. So they will be perfect before leaving.
1. kurfgator - Mazdaspeed 6 - Under-driven Accessories
2. BoostedSpd6 - Mazdaspeed 6 - Under-driven Accessories
3. mdogg - MS6 - Under-driven Accessories
4. Kosh - MS3 - ALT + Pump Pulley
5. sped56737 - MS6 - ALT + Pump Pulley
6. halfshaft5 - MS6 - Alt + Pump pulley and anything else for that matter....
7. ATE BALLER - MS6 - All lightwieght / All stock size
8. averia -MS6 - Stock or underdriven provided sourcing belts isn't an issue
9. JumpingJackson - MS6 - All Lightweight / all stock size
Normal 6s
I4
1. StickintheSix - Mazda6 I4 - Under-driven Accessories
2. JBalla1036 - Mazda6 I4 - Lightweight accessories
3. Rainmens-mazda 6i-any freakin accessory you can get me.
4. Business - 6i - anything, everything
5. TalonFyre - 6i - Lightweight accessories
6. macdonaldp 6i - Lightweight accessories
7. pray4mojo 6i - Lightweight pulleys
8. crystallas 6i & Fusion
9. mazda 6007 6i
10.osajek 2005 6i- Lightweight accessories
11.Big_D562 6i-Lightweight accessories
12.ro4fd 6i- Lightweight accessories
13. DeZi - Everything and Anything!!!
14. Xxxmonoxidechild - 6i Lightweight accessories
15. Wyvers 6i- Lightweight accessories
V6
1. Mazda6smtx - Mazda6 V6 - Under-driven Accessories
2. Nealio - Mazda6 V6 - Lightweight accessories
3.djquik1 - Mazda6 V6 -lightweight accessories
4. USAF 6S - Mazda6 V6 - lightweight accessories
5. leadbedr - Mazda6 V6 - lightweight accessories
6. Sport6 - Mazda6 V6 - lightweight accessories
7. VirtualMirage - Mazda6 V6 - lightweight accessories (stock size)
8. ktm173 - Mazda6 V6 - lightweight accessories (stock size)
9. The Great NY - Mazda6 V6 - lightweight accessories (stock size)
10. AutoExe Mazda6s- Mazda6 V6- Lightweight accessories (stock size)
11. xshellshock - Mazda 6 V6 - Lightweight Accessories.
12. rosem32 - Mazda 6 V6- waterpump pulley and powersteering pulley
13. tapdatmac - Mazda 6 V6- Lightweight accessories (stock size)
14. DLuxxx - Mazda 6 V6- Lightweight accessories (stock size)
15. Spidy - Mazda 6 V6 - Lightweight accessories (stock size)
16. fireguy0178 -Mazda 6 V6-lightweight accessories
17. Blazing Copper 6-Mazda 6 V6-lightweight accessories
18. Marko343-Mazda 6 V6-light weight pullies
19. triplejumper18 - Mazda6 V6 - everything
20. PALMZ43- Mazda6 v6-Lightweight accessories (stock size)
21. Awong124 - Mazda6 V6 - Lightweight Accessories
22. Benner410 - Mazda 3.0L V6 - lightweight accessories
23. Jayzon - Mazda 3.0L V6 - everything
Ya man, im sorry... alot of these guys cant register or wont take the time to do it lol. So im getting PM's from that "other site" and adding them. How would you like me to add them Brach?
Just add the name to the list what there other board name is and put next to it, From the Darkside and have them send paypal with that board name so I know when they pay.
Quick question, anyone know how to loosen the belt on the disi motor? I haven't exactly looked at it, but I imagine one of the pulleys has a pivoting braket. I just want to make sure I don't have to buy a $200 tool to install these. Mazda likes to make special tools to do normal everyday bs, that's why I ask.
Normal 6s
I4
9. mazda 6007 6i
16. twtraudio 6i-all pulleys
V6
are you going to make them for the 2.0L Mazda 3? Or does the 2.3L work for us 2.0 guys as well?
If you are/if it does I will buy just let me know first!
hey Brach,
I know this is a long shot, but would you be able to confirm whether or not the pulleys for the 2.3 6i are the same as the Fusion 2.3? Because I can prolly get a bunch more people in on this. The 3/6/Focus/Fusion and other 2.3 MZR/Duratecs all use the same waterpump, but I didn't want to assume anything based on that.
Normal 6s
I4
9. mazda 6007 6i
17. LUV5M6 6i- all pulleys
V6
I have been asked to keep this going until after the 6th. So I'll keep it going. In the mean time, I have started making the Solid works model and will have it finished after the new year.
Normal 6s
I4
9. mazda 6007 6i
V6
24. anotherM6 - Mazda 6 V6- Lightweight accessories (stock size)
Fixed
Normal 6s
I4
9. mazda 6007 6i
18. Y'he Sha'is 2007 6i - Lightweight Accessories
V6
Added myself to the list.
Normal 6s
I4
9. mazda 6007 6i
19. werm9 2006 6i- lightweight accessories
V6
Speed6
Normal 6i (4cyl)
9. mazda 6007 6i
20. madtes6i - lightweight pulleys
6s (v6)
Added another for the 6i
I was waiting for you to show up here Business.
List Fixed:
Speeds
6i (4cyl)
9. mazda 6007 6i
6s (v6)
List Fixed:
Speeds
10.RhoadBlock - MS6 - All lightweight / All stock size
6i (4cyl)
9. mazda 6007 6i
6s (v6)
I make it 10 for the Speeds.
edit: When is the latest you will accept payment, just so I know? I'm a bit tight on cash at the moment but in a week or so I should be able to get these.
Status
