GI: SplitSecond Air Fuel Controller
Mutmatt
MazdaSpeed Protege, Black Mica
You all know the deal, ProtegeGarage is looking into saving you guys some more money! Just throwing the idea of a GB on an item that i will be adding to my list of mods as well very soon, the SplitSecond Air Fuel Controller. Both versions would be available for order if we did this group buy and obviously the prices would drop at some of the key #'s, 10 being the first big price drop we want to hit!
You can fill in any of the gaps or ask any of the questions needed!
The Split Second Air/Fuel controller is piggy-back system that comes ready to use right out of the box. Preloaded with fuel maps for your application this product allows for the precise control of air and fuel your performance engine requires. Whether you just need to lean out the car across the board, increase fuel for higher boost levels, or run bigger injectors this unit can handle it all. Via the provided R4 software and a laptop you are able to tune on the fly, make real-time recordings of vital engine stats, and share maps with friends as easily as sending emails. With few wires to install and ultra tough construction the AFC can be mounted anywhere and installed in under 2hrs using common tools. In addition we keep a working database of maps made by us as well as maps submitted by your fellow tuners. Installing the new maps takes seconds and our tech support is always eager to answer any questions you may have. There are two options - Version I and Version II. Both are capable of datalogging capability however the Version II allows for Wideband Input as well!
On March 18th, 2007, ProtegeGarage road tested and analyzed a 2003 Mazdaspeed Protege using the Innovate LM1 wideband. We experienced throttle and boost hesitation with peak air/fuel ratios of 9.9:1 in boost. After installing the SplitSecond AFC, the hesitation was completely eliminated and air fuel ratios were a more acceptable, leaner mix of 12.3:1 in boost, freeing up more power and creating a more efficient fuel trim for the engine!
Now lets see the love! (outie)
hey now... when did my name get added... :)
depending on the time frame i will probably be in for a version II as well tho
hey who authorized this GB?
j/k let matt or i know if there are any questions
I would be in as well depending on when the money will be due by. Looking for version 2. What would be the price.
Curious what the price break will be, but im pretty sure i would be in to buy v2. Let us know the numbers. thanks
yeah whats the price?? price for v1 and v2 please
and i heard someone mention it doesn't go well in cold climats.. is it true?
