Compare auto reliability with reliable results at TrueDelta.com!
Page 1 of 2 12 LastLast
Results 1 to 15 of 21
Thread: feels like my car is pulling back power
  1. #1
    Garage Queen Spiced MSP's Avatar
    2016 Peterbilt 579
    Join Date
    Feb 2009
    Location
    Columbia, SC
    Posts
    3,680
    For some reason, when I am driving my car, as soon as my car sees boost it feels like it pulls back power. It drives fine during regular driving, but as soon as my boost gauge touches 0 or higher, it feels like the engine rocks and if I gradually give it more gas and get more boost, it will rock again and it feels like it is the car is losing power or something. The rocking thing with the engine is not huge, but I can feel a slight rocking motion as soon as the car sees boost. Of course the engine moves during gas on/gas off driving or shifting but this is not that. I gradually give it gas until the needle on the gauge reaches 0 and it pulls back. Any higher in boost and it feels like it pulls back more. any clue what it is? I don't want to blow my motor. I am ordering a split second air/fuel and timing controller and rear motor mount this week.
    RIP 1549 spicy totaled...
    2006 Toyota Tundra Limited Double Cab- No longer have
    Current Vehicle: 2016 Peterbilt 579 10 speed Eaton Fuller...lol. At least I get to still hear something spool up
  2. #2
    25ish_psi shane02pro5's Avatar
    Join Date
    Jun 2003
    Location
    Houston, TX
    Posts
    4,995
    Running higher than stock boost can easily cause fuelcut but that usually more violent like hitting a wall. I would check your plugs first to see if they look healthy if they are looking a redish brown you are running lean and shiny specs on them would be from detonation. Could be bad coils they are a common failure or the wga could be bad causing you to run higher boost and run out of fuel.
    GT3071R Dual BB 64a/r Steedspeed Mani SpeedCircuit block Arias 8.5:1 Pauter Rods Stage 1 Head AWR oil pan PAR 1-4 Straightcut gearset Haltech F10A J&S Safeguard w Knock Gauge AEM WB Autometer Boost EGT Gauges CS Radiator Walbro GSS342 Fuel Pump Perrin Fuel Rail JoeP FCD Denso Forester 730cc Injectors MSP LSD welded Competition Clutch Stage 5 SS clutchline & brake lines Pope 3" Dp My Custom 3" Boost Activated Cutout Polished Gauge rings Polished Door Sills B&M SS 16oz SS shiftknob Magnacore wires 4awg ground kit Nex Full Coilovers Racing Beat rear sway AWR endlinks DIY Mounts Bronzoil Bushings Redline shiftboot e-brake boot Rota P1 Black 18x8 Yoko S Drives 215/35/18 Sony headunit Sony 1000w 2ch Kenwood 550w 4ch Sony 12" Infinity Reference doors PA 2 farad cap
    FS P5 Rad, P5 OEM Intake , P5 Fans http://www.mazdas247.com/forum/showt...hp?t=123768336
  3. #3
    2016 Peterbilt 579
    Join Date
    Feb 2009
    Location
    Columbia, SC
    Posts
    3,680
    Quote Originally Posted by shane02pro5 View Post
    thanks for the info, I replaced my coils recently and I have experienced fuel cut before so I know it is not fuel cut. I will check my plugs and see how they look. It could be my wga but I tested the actuator recently and it was good. But, how could it be from running higher boost if it happens as soon as the needle on my boost gauge reaches zero. My car barely sees boost because I don't want to risk a blown motor.
  4. #4
    MSP Chick :) Metallic36's Avatar
    2003 Mazda6 3.0L Speed Yellow
    Join Date
    Jul 2006
    Location
    Lula, GA
    Posts
    3,138
    Have you checked your intercooler piping to make sure you don't have a leak somewhere? Mine did that once when I forgot to tighten a coupler on the hot side.. I wondered why I wasn't able to boost at all yet I was still able to drive it.
  5. #5
    2016 Peterbilt 579
    Join Date
    Feb 2009
    Location
    Columbia, SC
    Posts
    3,680
    Quote Originally Posted by Metallic36 View Post
    no, I will check that and see how it drives
  6. #6
    Registered Member
    2003.5 Titanium MSP
    Join Date
    Mar 2006
    Location
    Austin, TX
    Posts
    111
    Same
    Quote Originally Posted by Spiced MSP View Post
    Before I upgraded to the SLS Hot Pipe....the stock plastic pipe had a nice tear/hole in it...still allowing me to drive, but basically 'bucking' the second it got to 0. Sure you can get it PAST 0, but most of the air is escaping I'm sure.
    Anyway, it bucked around enough to break the intake vibra-mount thing, and obviously I couldn't boost...so...it was time to fix!! But yeh, didn't see hard pipes or anything on your mod list, but maybe I skipped over it...if you have the stock one still, it might be broken now....but even when I put on the SLS pipe, the couplers weren't tight enough initially so I still had leakage.
    ____________________________________
    2003.5 Titanium MSP - 5% Tint all around
    Autometer Triple-Pod w/Ultra-Lite Gauges
    Greddy FATT (waiting...)
    Injen Cold-Air Intake
  7. #7
    2016 Peterbilt 579
    Join Date
    Feb 2009
    Location
    Columbia, SC
    Posts
    3,680
    Quote Originally Posted by tolagarFriS View Post
    I have a FMIC, no plastic pipes anywhere. I will check all of my couplers and make sure they are tight. I just recently noticed it could be my BOV also. The piston may not be seating all the way.
  8. #8
    Registered Member
    Join Date
    Jul 2009
    Location
    Long Island, New York
    Posts
    591
    This is my answer to everything...coil pack!
    Do you get full boost otherwise?
  9. #9
    Join Date
    Jul 2006
    Location
    Lula, GA
    Posts
    3,138
    But he mentioned he just replaced his coils recently..
  10. #10
    Registered Member
    Join Date
    Jul 2009
    Location
    Posts
    591
    O...maybe they went bad?
    Kidding.
    I'm having trouble actually picturing his problem.
  11. #11
    2016 Peterbilt 579
    Join Date
    Feb 2009
    Location
    Columbia, SC
    Posts
    3,680
    sorry guys, I know it is hard to help. But, it is hard to actually explain what my car is doing. For instance, If I am driving at highway speeds(65+ mph), and I very slowly start giving the car more gas, the needle on my boost gauge starts to rise. As soon as the needle reaches zero, it feels like the engine rocks and the car loses a little bit of power. Someone on another forum mentioned that it could be my rear motor mount. I don't know. I am ordering the rear mount next week anyway. I already know how much of a bitch it is to replace it. But, I have access to some air powered tools and a lift at a garage here on Ft. Hood. Thanks for the info so far guys. I really appreciate it.
  12. #12
    2016 Peterbilt 579
    Join Date
    Feb 2009
    Location
    Columbia, SC
    Posts
    3,680
    Quote Originally Posted by bolou17384 View Post
    ???What??? ^^^^^^
  13. #13
    Banned
    mazda speed protege
    Join Date
    Mar 2009
    Location
    bakersfield, ca
    Posts
    275
    i would do both front and back. my car feels different when i did that..
  14. #14
    2016 Peterbilt 579
    Join Date
    Feb 2009
    Location
    Columbia, SC
    Posts
    3,680
    Quote Originally Posted by jeanspeed View Post
    yeah, I am going to order the rear mount next week, I am not looking forward to installing it though. lol
  15. #15
    Banned
    mazda speed protege
    Join Date
    Mar 2009
    Location
    bakersfield, ca
    Posts
    275
    cool. i have both f and b awr i think i got 90. the car feel cool when they where installed. well good luck
Similar Threads
  1. Car feels like its pulling
    By superbobu2 in forum Mazda6 Wheels, Tires, Brakes & Suspension
    Last Post: 09-18-2008, 04:34 PM
  2. HKS Hi-Power Cat Back Exhaust
    By Hauce1 in forum Protege5
    Last Post: 10-22-2006, 12:07 PM
  3. WTB: HKS Hi-Power Axle Back
    By Boston5761 in forum Completed Transactions
    Last Post: 07-06-2005, 06:45 PM
  4. p5 hks hi-power axle-back on msp?
    By supman in forum Mazda Protege
    Last Post: 10-29-2003, 02:56 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
