Shocks and struts were another early job. I was super excited for Koni Special Actives, having experienced the old FSDs on a friend's E46 3-Series. It rode spectacularly, and the only complaint I ever heard was weird limit handling. Seemed like a completely fair tradeoff for a FWD family hauler.
The front Special Actives are shared with Volvos, which means they’re available on FCP Euro. Not much of a value add as they are already warrantied for life through Koni; the main benefit of FCP Euro’s warranty is that it’s basically unconditional.
To aid the job, I had
this tool from working on my M3, which also has MacPherson struts with clamps up front. You stick the tool in the gap vertically, put a wrench on it, crank it 90º, and it spreads the clamp. Made it much easier to get the struts out.
Wasn't enough to get the new ones in, though – but it helped. For final assembly, I used a big flat-head screwdriver that happened to have a 10mm hex shaft. With a jack pushing up on the spindle, I stuck the screwdriver head in the gap, put a 10mm open-ended wrench on the shaft, and cranked until the strut popped into place.
Installed pics:
Thought it was weird that the PS strut has that nice fin on the back but the DS one doesn't. Made the DS one more annoying to line up. Nothing a Sharpie and some fiddling couldn't fix, though.
I originally went with Sachs from Rock Auto for the strut mounts. Figured that if the stock ones were keyed for LH/RH, I should probably stick with ones that were also keyed that way. So, I ordered the pair...
...but inside the box for the PS mount (left), there was another DS mount!
Wanting to get the car back on the road in short order, I overnighted another Sachs PS mount from Autozone. I got yet another box with the correct part number printed on the outside but the wrong part inside.
Figured it had to be a warehouse issue or something, and that I'd need to look elsewhere. The only decent-quality replacement I could easily get my hands on was a KYB – which doesn't have the locating pin, so can be used on either side. An Autozone near me had one, so I could get it same-day. So, now I have one Sachs and one KYB strut mount. #ShrugLife
The one functional part I neglected to replace was the front bump stops. The ones that were in there looked okay so I thought nothing of it. Hope that wasn't a mistake.
Forgot to take pics of the rears, sadly. Easy AF though, and I'm sure y'all know what they'd look like. Special Actives, KYB shock mounts, VW MkIV Golf bump stops (because FCP Euro), and whatever boots the car came to me with.
Initially, ride quality was... interesting. Nice and smooth over most roads, but crashy as heck on big bumps. Turns out a lot of the crashiness was due to some combination of:
- Completely shot front LCA bushings,
- Worn ARB end links, and
- Worn ARB bushings.
I say this because, after replacing all of those, it got much better. I went OE Mazda for the front LCAs and ARB bushings, and Lemförder for the ARB end links (FCP Euro again).
The ARB bushings were a massive PITA! I could not for the life of me get the brackets on. Factory procedure is to pull the subframe so the bar can be worked on off the car, and then press the brackets on with a vise. I used silicone spray to get the brackets most of the way on – enough to get the bolts in – and then used the bolts to push the brackets the rest of the way on. If this was a mistake, I’m sure I’ll find out in due time!
More detailed discussion on front struts and ride quality here:
Koni Special Actives installed. Smooth but crashy?
...But, suffice it to say I'm now happy enough with how the car rides that I'm not in a hurry to re-do anything. The overall ride is buttery smooth, body control is quite good, feedback and feel are great (all in the context of this kind of vehicle, of course). And it'll only get better after I complete a refresh of the rear suspension, which will hopefully be in the next week or two (we'll see).
